FlatTrackinIt55 Posted October 3, 2004 Report Posted October 3, 2004 For this, i came to the Banshee Guru's. I know that you can put a 600 streebike clutch in banshees , many dragracers run them but im unsure of what clutch it is.. is just a regular yfz r-6 clutch or is it something else?? any help would be appreciated, thanks in advance Quote
racer Posted October 4, 2004 Report Posted October 4, 2004 r6 or an fzr600, same motor but in two seperate states of tune. Quote
BANSHEE_JAY Posted October 20, 2004 Report Posted October 20, 2004 Be Great but but can anyone proove this be an expensive experiment !!!! Quote
Big Blue Posted October 20, 2004 Report Posted October 20, 2004 (edited) fzr 600, fzr 1000, and r6 read this at planet sand. Edited October 20, 2004 by Big Blue Quote
fixitrod Posted October 20, 2004 Report Posted October 20, 2004 fzr 600, fzr 1000, and r6 read this at planet sand. any year? Quote
Big Blue Posted October 20, 2004 Report Posted October 20, 2004 didnt say anything about year that is all that was posted Quote
rebelbanshee2 Posted October 20, 2004 Report Posted October 20, 2004 im not sure the YZF-R6 or FZ-600will work I think its just the FZR600 and FZR1000 Quote
racer Posted October 20, 2004 Report Posted October 20, 2004 im not sure the YZF-R6 or FZ-600will work I think its just the FZR600 and FZR1000 i know the FZR and r6 are the same motor, just tuned differently. im not sure about the other two, but ill find out at work tomorrow. Quote
rebelbanshee2 Posted October 21, 2004 Report Posted October 21, 2004 i think you are confusing the old FZRs with the new FZs The FZs are the same basic engines as the YZF-Rs The FZRs are older completely different bikes. Quote
2Smoker Posted October 21, 2004 Report Posted October 21, 2004 I would really like to know. You would think the 600 clutch plates would be alot stronger and durable than a banshee cutch because of the bigger motor. Has anyone actually tried this? Quote
98bonerSTOCKshee Posted October 21, 2004 Report Posted October 21, 2004 I would really like to know. You would think the 600 clutch plates would be alot stronger and durable than a banshee cutch because of the bigger motor. Has anyone actually tried this? I am with you... has anyone done this? What are the real advantages? Quote
snowprophet1 Posted October 21, 2004 Report Posted October 21, 2004 Yamaha pt # 4H7-16321-02. More surface area than stock banshee. It has more clutch material towards the ID. The rubber 0-ring spacers found in the stock banshee setup are discarded and the clutch material takes it's place. Good trade off! Quote
racer Posted October 21, 2004 Report Posted October 21, 2004 one type of plate is thicker also, i dont remember if its the steel, or fiber. but since they are thicker its likes having stiffer springs. Quote
fixitrod Posted October 21, 2004 Report Posted October 21, 2004 one type of plate is thicker also, i dont remember if its the steel, or fiber. but since they are thicker its likes having stiffer springs. I'm not sure how it could be like stiffer springs if the clutch is adjusted right. Quote
98bonerSTOCKshee Posted October 22, 2004 Report Posted October 22, 2004 are all the plates replaced with the street bike, or just a few? Quote
