xt45 Posted September 29, 2004 Report Posted September 29, 2004 Which One To Buy Brand New Banshee or Used Banshee and Why Quote
NYUK Posted September 29, 2004 Report Posted September 29, 2004 buy both. then you could have the best of both worlds. new and used.put the new one in your living room as a piece of furniture. a conversation piece.you could sit on it and practice shifting gears.waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa, Quote
tithead Posted September 29, 2004 Report Posted September 29, 2004 buy both. then you could have the best of both worlds. new and used.put the new one in your living room as a piece of furniture. a conversation piece.you could sit on it and practice shifting gears.waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaawaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa, which ever 1 you end up getting, have fun! if your going for the second hand shee make sure you have a look at it before you buy and make sure it up to scratch and your happy with it! Quote
nickxc Posted September 29, 2004 Report Posted September 29, 2004 both have advantages, if you buy new you know no one has touched it before you and its all up to you how it is maintained and how it runs. The advantage of a used one is you can get one with some mods (pipes, filter, reeds, head, etc....) for less than the price of a new one. If you buy used just go all through it before you hand over the cash. I usually look at all the little things, cleanness, on the kick start side of the motor you can tell how much riding it has had by how much paint is worn off on the case, they all do it and depending on how much it has been ridden more paint (or less) will be worn off right under and in front of the kicker. take a compression guage and put that on it, fire it up and move it in gear a little at least, make sure it shifts ok and the clutch is working good, bring something to put the front end and rear end up on, check A arm bushings and front and rear bearings for back and forth play and looseness. just a few things I do when buying a used shee... Hope this helps!!! Quote
racer Posted September 29, 2004 Report Posted September 29, 2004 (edited) buy three blaters instead. one to drag out so that it will beat a piped banshee, another to sit in your backyard as lawn furniture. drop the third into the ocean as use it as a synthetic coral reef, its all the rage these days. Edited September 30, 2004 by therail Quote
fixitrod Posted September 29, 2004 Report Posted September 29, 2004 I say used also. By the time you have the amount of money a new one cost you could have a lot of aftermarket goodies for the used one. Quote
banshee76179 Posted September 29, 2004 Report Posted September 29, 2004 I say used also. By the time you have the amount of money a new one cost you could have a lot of aftermarket goodies for the used one. Quote
