Ultimateduner Posted September 21, 2004 Report Share Posted September 21, 2004 I've decided to put on 28 bored stock carbs on my piped banshee. I was wondering what performance gain if any, I would get through this. I ride in sand with an after market airfilter and fmf pipes. Quote Link to comment Share on other sites More sharing options...
roosthrower Posted September 21, 2004 Report Share Posted September 21, 2004 you probably wont gain all that much with a stock motor and all. I'd say the gain would be comparable to putting on a set of aftermarket reed cages. one or two horsepower and maybe a ft/lb of torque with most of the gain coming at high rpm. Quote Link to comment Share on other sites More sharing options...
Ultimateduner Posted September 21, 2004 Author Report Share Posted September 21, 2004 Yeah I might be getting reeds as well Quote Link to comment Share on other sites More sharing options...
MotulMonsta Posted September 21, 2004 Report Share Posted September 21, 2004 Don't waste the cash on bored out stock carbs..The V-force reeds you want to get will out flow them. Kehnin PWK's are a real good choice carb wise but you'll need to run reed spacers to clear the float bowl vent lines. Think about what kind of riding you will mainly be doing. 28mm is a good choice for woods/trails/MX..any type of riding requiring max low end response..but the banshee will really wake up with a set of anything over 30mm. Quote Link to comment Share on other sites More sharing options...
Ultimateduner Posted September 21, 2004 Author Report Share Posted September 21, 2004 (edited) Don't waste the cash on bored out stock carbs..The V-force reeds you want to get will out flow them. Kehnin PWK's are a real good choice carb wise but you'll need to run reed spacers to clear the float bowl vent lines. Think about what kind of riding you will mainly be doing. 28mm is a good choice for woods/trails/MX..any type of riding requiring max low end response..but the banshee will really wake up with a set of anything over 30mm. Thanx for the help but I still want to have some bottom end after all this Edited September 21, 2004 by Ultimateduner Quote Link to comment Share on other sites More sharing options...
