Can you put one together for a tapered bearing? Because I KNOW what you mean... "I can get a great bearing for $1 each" then go and buy it. It's made out of recycled soup cans but that's good enough for you banghead
Since you can get your own bearings, PM me a bearing code, and I'll check on it. If its the SAME dimensions as a 6007 then yes. If not, I will have to wait until my next run, that is, if I can get aluminum :unsure: Well, maybe you can find out what the dimensions are if you can. If not, just the bearing size code.
On the bearing cost...I found the 6007 bearings as high as $34 EACH at my discount...Retail at around $40. I have also found bearings on the very very bottom at around $3-$4 each. I won't sell those...but I do sell a nice middle of the road bearing.
Yep give gary a call at the number on the webpage. He will do you right, and build your swingarm to whatever specs you want. He stands behind his products 100%
:whoa: WTF, did they already send you back home??? J/K, didn't expect to be hearing from you so soon.f Be safe! ;)
OK... CEJ the bearing number is 32007X it is 35mm bore 62mm OD and 18MM thick. My cost is about $30 each without buying any quantity. The available seal is 5MM {as I recall}. I would think that all you would have to do is bore your regular dimensions a little deeper and just allow for your seal thickness.
Let me know if that's do-able.
  • 3 weeks later...
