And thats all there is to it it just boggs horrible everytime you touch the gas whecter it be shift letting off thegass then getting back on it, starting out in 1st its gettin redic also seems to be runnin hot.. HELP banghead
you have a tors removal kit? is this starting doing this out of the blue it could be that your parking brake lever is on a bit or your throttle sensor went bad. please give us more info.
How is the idle...does it sound like it is idleing faster
since this problem began? Does it get hot and then
run crappy or does it run crappy even when it is just warm?
Did the problem start during a ride? If not, how long had
the bike been sitting since the last time you rode it and it
was fine? Does it make enough power to be able to shift up
through the gears?
Tors is removed parking brake is removed, runns like this hot or cold but latly has been runnin much hotter, pretty much happnd overnight put it away after it ran great took it back out the next day and its runs like a 250ex, everythime u hit the gas it just bogs, but even when it finly does hit powerband the powerband is weak not what it usally is, this bike was just rebuilt and ran like a raped ape for 2 weeks not its just sucks, its runnin hot and boggin real bad its getting almost impossible to even start it off in 1st gear becuse it boggs down to the point where it just stalls
parking brake connections?
bad reed(s)?
air leak?
crossover tube not on right or at all?
bad gas?
bad mood?
and of course,
bad jetting?
have you looked at the plugs after it does this and stalls to see if they're oily nasty black or not?
Edited by sredish
