98TEAM ALBA Posted August 31, 2004 Report Share Posted August 31, 2004 What is an alternate carb setup(i.e. 2into1, 28mm) that you can run on a stock ported engine with pipes without trouble? Quote Link to comment Share on other sites More sharing options...
fixitrod Posted August 31, 2004 Report Share Posted August 31, 2004 I've heard of people running 30 - 32mm with top end pipes for drag racing. Quote Link to comment Share on other sites More sharing options...
Banchetta Posted August 31, 2004 Report Share Posted August 31, 2004 What is an alternate carb setup(i.e. 2into1, 28mm) that you can run on a stock ported engine with pipes without trouble? Stock carbs are the best for stock porting. Any larger will yield less hp. I never got a chance to test the 2 into 1 setup though and I'd think they might have a gain for all around power since the ported stock carbs lost hp on the dyno, I would have liked to try a set up smaller carbs or single setup...never got that far and ended up putting a stroker in. Quote Link to comment Share on other sites More sharing options...
dave95.1 Posted August 31, 2004 Report Share Posted August 31, 2004 mine is stock porting with just pipes and i really like the 2-1 setup. Quote Link to comment Share on other sites More sharing options...
