bansheewizard Posted August 29, 2004 Report Posted August 29, 2004 ok my pipes on my banshee spits the oil out the pipes and its the oil out of the gas done checked so im tryin to jet it where it will stop does neone have this set up or close to in and whats your jetting mine is 34mm carbs 165 main 58 pilot port ploshed shaved head .60 over fmf fatties and slincers v force reeds pro flow air itake and no air box with uni filters need help pleasse it pisses me off haveing to clean the oil off my swing arm plastic motor Quote
SDD Posted August 29, 2004 Report Posted August 29, 2004 What the hell did you just type? I can't understand a single sentence... well maybe it's because all that is one long sentence! Retype that thing and give us specific information about your current jetting, tempature, altitude, and mods. Quote
2Smoker Posted August 29, 2004 Report Posted August 29, 2004 165 main jet?? WTF?? A stock main jet is 200 (1987-89 is a 210) are you on crack? Quote
zilladude Posted August 29, 2004 Report Posted August 29, 2004 165 main jet?? WTF?? A stock main jet is 200 (1987-89 is a 210) are you on crack? He has Keihin carbs not mikuni's Quote
97redshee Posted August 29, 2004 Report Posted August 29, 2004 those 34mm pj's are a waste unless that thing is fully drag ported.im not that sure on the jettinfg im at sea level and have a 4mm stroker dune ported with same carbs and i run 148 main 55 pilot needle 5th clip.i make 77rwhp and 43 ft lbs. Quote
sredish Posted August 30, 2004 Report Posted August 30, 2004 those 34mm pj's are a waste unless that thing is fully drag ported.im not that sure on the jettinfg im at sea level and have a 4mm stroker dune ported with same carbs and i run 148 main 55 pilot needle 5th clip.i make 77rwhp and 43 ft lbs. agreed! trade them for some 28s or maybe 30s, and do yourself a favor. that's just way too much air unless your stroking, even then that's too big for my taste unless your draggin... Quote
