repacking silencers
its fairly easy
take the outside cover off the inside core with 3 bolts (depends on the silencer) then cut all the old silencer packing out, then wrap the new shit on there, not to tight, but not to loose, you'll figure it out when you try to stuff the core back inside the outter shell, and your done
There is a company called Silent Sport. They make a sleeve that you just slide over the core of your silencer. They work great and last longer that that wrap on packing. Cheaper in the long run also. Your local quad dealer should be able to order you one. B)
