i am thinking of buying the k&n filters that go directly onto the carbs but i hear if they fall off you have to rebuild the whole motor and i dont feel like doing that how do you guys keep them from falling off
just make sure they are seated all the way on the carbs. and make sure the clamps are tight. never had any problems with mine.
What badshee98 said. And important you buy the outerwears too. I also used some plastic tie straps to further secure the outerwear's.
Remember to rejet your mains!
This is how I did it, works great and haven't come off in the 12 years I've had them like this.
Edited by BdBanshee
thse brackets look dope.
i havent had any problems with mine.
just keep a close eye on them
and the oputerwears are a must.
with my mods i think i jetted mine to a 290 main but its been so long i cant remember what the needle clip is at.
i have been thinkin about converting to alky but heard its a pain cleaning the carbs after each ride
lates
chris
nice mod job bdbanshee. i also have the k & n's on and have not had a problem with them slipping. make sure they end is free of the prepackaged oil. it can make them slip.. if they are tight it should be fine. it never hurts to double check they are on before you ride. i had to cut the air box stubs off the frame cuz they rubbed thru the outerwear. mine is jetted to 310 second notch from top. and is a perfect burn. and tank is simply zip tied to front frame. good luck.
the slanted K&Ns fit much better. Just ziptie your coolant bottle under the nose of your bike. It prevents coolant from splashing out onto your pipes when you locate it there.
Edited by Justintoxicated
I got my K&N's from Rocky Mountain and they offered a cool coolant bottle relocator bracket. I ordered the bracket that has holders for spare plugs too. It wasn't that much $!
