thecabinboy Posted August 23, 2004 Report Share Posted August 23, 2004 Just installed a kit. It contained a new Bi-wound spring and a ball bearing shift arm. Has any one else used this set up yet? I probably wont ride for another month or so and was wondering if it was worth the money (35 on Ebay)? Quote Link to comment Share on other sites More sharing options...
banshee04le Posted August 23, 2004 Report Share Posted August 23, 2004 It lightened your wallet. Lighter is faster. Sorry, I don't know. What's the theory behind it? It looks like stock parts. Is the spring stiffer? Is the arm longer or shorter? Quote Link to comment Share on other sites More sharing options...
JTQuad Posted August 23, 2004 Report Share Posted August 23, 2004 Im also curious how it works, If its good, $35 is cheap to spend on a mod - JT Quote Link to comment Share on other sites More sharing options...
jinx44 Posted August 23, 2004 Report Share Posted August 23, 2004 $35!? I paid $70 for the ones I bought and would pay that again. The shift pro works awesome. I have a cut star also. It takes VERY little effort to lift the shifter with the shift pro. The spring is considerably softer. If you are worried about a soft spring, I think even the roller would be an improvement with the stock spring. Just to give you an idea how much it helps, I can't even turn my star by hand with the stock setup, but with the shift pro I can easily roll it around. I am headed to ebay right now to get another if they are only $35. By the way, aftermarket shifts help a lot. Stock shifter flex WAY to much. Just checked ebay and the only ones I see are still $69. Quote Link to comment Share on other sites More sharing options...
thecabinboy Posted August 23, 2004 Author Report Share Posted August 23, 2004 (edited) it was 35 because it was used I guess? looks fine to me. Edited August 23, 2004 by thecabinboy Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted August 23, 2004 Report Share Posted August 23, 2004 Interesting. Quote Link to comment Share on other sites More sharing options...
sinister shee Posted August 24, 2004 Report Share Posted August 24, 2004 IVE GOT ONE WITH A MODDED SHIFT STAR IT WORKED AWESOME EXCEPT I STARTED HITTING NUETRAL ALOT OR STUCK BETWEEN GEARS, NUETRAL EFFECT IM NOT SURE WHICH ONE, SO I PUT THE STOCK SPRING BACK IN SEEMS TO BE WORKING GREAT. WAY EASIER ON SHIFTING DEFINATELY WORTH THE MONEY Quote Link to comment Share on other sites More sharing options...
