lokar Posted August 22, 2004 Report Posted August 22, 2004 Okay, I installed a Motion Pro throttle kit and an idle kit. I synced the carbs and the bike is running awesome. The only problem is, I cant get the bike to idle. even if I put the screws all the way in, it dies. before I put everything together I checked, and the screws go all the way through and lifts the slides for sure. Was I supposed to 'flatten' out the boss the screws go into? (it has a small angle to it) Unfortunately the kit didnt come with any instructions. Quote
lokar Posted August 22, 2004 Author Report Posted August 22, 2004 I investigated things a little mare, and I discovered fuel in the 'overflow' tube that runs out the back of the carb. it also lookas like there hase been some fuel coming out of one of the side tubes on the other carb. Any ideas? The bike runs super strong on the top, but I think its getting flooded when I lift. ? I just cleaned everything up. I didnt do any measuing on the floats, but they seemed to be okay. Also, when I make adjustments to the piolot jet screws, there is no noticable difference. Quote
sredish Posted August 22, 2004 Report Posted August 22, 2004 does sound like your floats may need some adjustments. Quote
slowpokebanshee Posted August 24, 2004 Report Posted August 24, 2004 sounds like you need to file some material off of the carb body, if they are still beveled. I can't remember exactly, but I think the instructions say something about 2mm need to be removed. goto toomey's website, they have instructions you can print out. Quote
