Well I'm thinking of selling or parting out my 2000 banshee because i don't feel like or have the time to work on it anymore and wanted to know what you guys think i could get for it.
Engine
421 powervalved cheetah cylinders mx port / 4mm long rod hotrods crank trued and welded / 35mm pwk carbs / aluminum airbox / uni filters / V-Force reed cages / cut transmission (not over ride) / alba shift drum / rz shift forks / hison clutch basket / barnett clutch / hydraulic clutch with stainless line / terry cable throttle / dyna CDI ignition / NOLOGY coil / ricky stator / 68mm wiesco prolites (blaster) / pingel fuel petcock / toomey radiator / alba clear coolant lines / prodesign impeller.
Chassis
lonestar 2+1 a-arms / lonestar -1 swingarm / lonestar axle carrier / lonestar +4 axle / lonestar locking rear hubs / lonestar brake hub / wave rotor / hiper tech carbon fiber wheels 10x10 dual beadlocks / holeshot xcrs all around / elka elite rear shock dual rate, remote resevoir / lonestar tierods
probably some other bits and pieces that i can't remember right now......
