loganskinner Posted August 10, 2004 Report Posted August 10, 2004 ok so i have tried everything that i can possibly think of to stick my grips to the bars and NOT ONE DAMN THING has worked... ive tried grip glue, hairspray, super glue, liquid nails, model glue, and a few other things, i glue them on, wrap them tight with wire, and let them set for at least 2-3 days before even touching them, and then as soon as i take and grab the grip, they both just slip off... anyone know any tricks to this? i know the stock ones had to be cut off, what does yamaha do? or could it be my grips? i use the cheaper, MOOSE RACING grips and they fit well, they just wont stay on. thanks. Quote
dogboystoy Posted August 10, 2004 Report Posted August 10, 2004 Well, I have cheaper aftermarket handle bars with a twist throttle. I used aquanet hairspray and it works great. But, for you I would take your grips off, sand paper the area of the handlebars (to get a textured pattern for the glue to stick to). and let them sit for a few hours or days if possible. Use the hairspray, or try whatever you have around the house that will get sticky. Do you have teflon for handlebars or what? Quote
stclark04 Posted August 11, 2004 Report Posted August 11, 2004 did u try using spray paint? thats all ive ever used and ive had good luck.. worth a try.. Quote
stealthawd Posted August 11, 2004 Report Posted August 11, 2004 i use spray paint too....never any problems do like was mentioned earlier and make sure your bars are clean...sand the area and wipe good with alcohol and let dry, then try again Quote
Gargamel Posted August 11, 2004 Report Posted August 11, 2004 Here's works for me every time Get your grips and clean the hell out of them (on the inside) with Gas then like stated before sand the bars a bit to give them texture(nothing sticks to a smooth surface well) Next get gas and wet LIGHTLY the bars and grips slide on don't touch for 1 day Never failed me yet Quote
loganskinner Posted August 11, 2004 Author Report Posted August 11, 2004 thanks guys, ill give some more stuff a try, and ill let you know. these things have become a real pain in the ass, i mean in the past, all ive had to do is spit on the bars, and slide the grips on and they never come off. i dont know, ill keep you guys posted, and thanks again for the suggestions Quote
frocashmoney24 Posted August 11, 2004 Report Posted August 11, 2004 moose grips SUCK! i have a pair on my fat bars and they used to slip. the left one has split at the bottom, but after paint and wire doesent move, and the throttle is a twist, and when i put paint in there it messed up my throttle and i had to take it off and clean the paint off, and use glue, which is holding, but that trip tore in half. next time im gettin scott grips Quote
fixitrod Posted August 11, 2004 Report Posted August 11, 2004 I was at coalfest in all the rain. I had trouble too. Banshee370 had some pwc grips (jet ski grips) and I'll never use atv grips again. I used honda glue and saftey wire. Quote
loganskinner Posted August 14, 2004 Author Report Posted August 14, 2004 well so far it looks like the "liquid nails Perfect Glue #1" is holding up. havent touched it in like 4 days because of the hurricaine that just came through here, and i waded out to the shee this morning, and they seem to be on pretty good. ill let you know how they hold up. Quote
QuadMX Posted August 14, 2004 Report Posted August 14, 2004 I always get Scott Hurricane MX Grips. Really love them. I spray the inside of them with some chain/cable lube and slide them on...Let them sit for an hour or two and bam. They don't move. They like to turn while I'm riding...but usually only if I'm riding hard. Quote
John19 Posted August 14, 2004 Report Posted August 14, 2004 I put them on with an air compressor and never use anything to "spray" in there and slide on. MIne have worked fine for years. Quote
Banshee~ Posted August 14, 2004 Report Posted August 14, 2004 We used spray paint on my bros kx and rode it 1hr later Quote
yamaharacr34 Posted August 16, 2004 Report Posted August 16, 2004 dont use moose, i think they suck...i use Pro Grip, they work awsome Quote
