does anyone have a good picture of a backed out nutral on the shift star? i ran the little tits on the leathe and took those things down. just really have no idea what im doing to back nutral out. i went to thebansheezone and that picture didnt really show me anythiing. any help would be great thanks. :clap:
thanks. it was roostfest that i went to not the banshee zone, my bad. im not able to back out nutral like that i quess ill just stick with the other mod. i have no money sice i got last emergency room bill. 4,000. just for 4 scans, 7 staples, and a few bandaides. nice picts, the moded shift star shows the same dimention as the stock. .350 i think it was. people actually charge 50 for this mod, thats nuts, aint it? :bolt:
No milling machine? Damn that sucks, looks like you'll have to cough up the 50...
BdBanshee, excellent pics, thanks for sharing!
i dought you could have messed up too..after all you used a good leathe and you didnt mess with nutral......seriously...is the shift shaft adjusted right, there is only one way to install the star on the drum..the climers goes over shiftshaft adjustment
I agree with RebelBanshee2, if you haven't backcut neutral I doubt you messed it up. Probably didn't get the shift shaft centering screw adjusted correctly.
BTW, if you read the pics it says that the .350" dimension is after modifying.
FYI I think Boonman does this mod for around $20
Something isn't installed corrctly. That's for damned sure. In the clymer manual, it details how to adjust it properly. Also, is it shifting, is it not disengaging? Is it a clutch problem, or a shifter problem? I doubt you could mess up the shift star without some serious misguided effort. And $50 is a ludicrous price. I can get you a brand new modded star for under that... Not just a mod... Man oh man..... How people survive without spending a few moments to lok around at different options.....
right theres the problem.... did you grind down the "arms" "lobes" on the star.... or did you grind down the little tits protruding out the side of the star ??
