hey guys ,i,ve had the clutch apart once since mods to measure plates and fibre's and all measure good.springs alittle light on ,but still with in limits,can i put heavier springs in or go the full clutch kit ???
better springs will help it from slipping but you should get a better clutch lever too or your arm will get sore after a while with the extra spring action there. thats if all the plates were to spec and aligned right.
Yeah, you can slap in heavier springs..but the stock plates will wear faster. I'm not shure where you can find heavier springs without ordering a kit but I assume that if you order from a larger displacement bike, they'll have heavier springs.
