KHALIL Posted July 12, 2004 Report Posted July 12, 2004 ok im looking for new pipes for my stock 03. before you think that im asking the "which pipes are best for me" question, ive already searched though this website and i know im gonna need low to mid range pipes like mabey gnarlys. the question is can i get it without any major mods and without sacrificing that awsome top end. or do the pipes boost it overall just not as much at the top end. also how much affect will reed spacers have on low end with pipes sorry for long read Quote
sredish Posted July 12, 2004 Report Posted July 12, 2004 the question is can i get it without any major mods and without sacrificing that awsome top end. low end pipes are not top end pipes, a low end pipe will diminish your top end... if you want to keep your top end then your going to have to get a midrange to top end pipe. it sounds like you want some decent low and good mids, so an all-around pipe is what you need. FMF Fatties FMF SSTs Paul Turner Mids Pro Circuits those come to mind. Quote
tats4life Posted July 12, 2004 Report Posted July 12, 2004 imo pt mids on a stock motor are a waste of money, get some fmf gnarlies or fatties. just my .02's. Quote
03limitededition Posted July 12, 2004 Report Posted July 12, 2004 The gnarlies are great pipes IMO, They Increase bottom and mid power with AT LEAST stock like top end (I think maybe a little more on top, but I have other mods). I wouldn't worry about reed spacers, I would just upgrade the air filter setup, If you havent already, and run the gnarlies. I have the gnarlies, K&N, 3 degree advance key, 145psi head, TDR reeds, and I went up one tooth on the countershaft sprocket, Runs Fantastic. My .02 Quote
bansheeryder_69 Posted July 13, 2004 Report Posted July 13, 2004 I'll sell you my fatties and powercores for $500 they are a mid and top range pipe and look tight. I want to get some cpi or drag pipes. Quote
jadaven Posted July 13, 2004 Report Posted July 13, 2004 The pro curcuits work well for me. Haven't thought of changing them at all. Gets some more low to top and has worked good with all my mods. Quote
TTG-Shee14 Posted July 14, 2004 Report Posted July 14, 2004 the question is can i get it without any major mods and without sacrificing that awsome top end. Welcome to the world of Machines! Quote
Wassup350 Posted July 15, 2004 Report Posted July 15, 2004 Get some Dynoport 2 into 1 pipes. They give awesoem low end to mid range power. They sound wicked too, probably the best sounding pipe i have heard. Quote
Ducman Posted July 17, 2004 Report Posted July 17, 2004 You have stock pipes now right? Any duel pipe setup will give you more top end than stock and generally more power throughout the entire RPM range. The low to mid range pipes like will add more power on the bottom end and mid and fair amount on top. 2 into 1 pipes will add a lot on the botom with a similar top end to the stock pipes. Some high rev pipes may cause a bit of loss on the low end over stock (not much) but will add a lot on the top end. Quote
