svtkid78 Posted July 8, 2004 Report Posted July 8, 2004 When I give it gas the emulsion tube is lifting up off is seat. Why Quote
frocashmoney24 Posted July 8, 2004 Report Posted July 8, 2004 What is an emulsion tube? yea what is it? Quote
sredish Posted July 8, 2004 Report Posted July 8, 2004 What is an emulsion tube? yea what is it? third here... what the hell is an emulsion tube. e Quote
randelator Posted July 8, 2004 Report Posted July 8, 2004 a emultion tube is the balance tub on top of intake boots Quote
frocashmoney24 Posted July 8, 2004 Report Posted July 8, 2004 the crossover tube is called a "emulsion" tube? are you sure its tighened all the way Quote
Toomey Banshee Posted July 8, 2004 Report Posted July 8, 2004 hmmmmmmm, emulsion tube , cross over tube is more like it. I would suggest you get new clamps ASAP. You dont want any crud in your carbs. Quote
svtkid78 Posted July 9, 2004 Author Report Posted July 9, 2004 I am talking about the needle jet it is also referred to as an emulsion tube Quote
zilladude Posted July 9, 2004 Report Posted July 9, 2004 Are you missing the washer for the main jet or is your main jet loose? Quote
Oilsmoke Posted July 9, 2004 Report Posted July 9, 2004 Good Call Zilladude. That is how you remove them and the only way they can move up. you need the brass washer under the main jet. this holds down the needle jet or froth tube or emulsion tube. Quote
