Anyone running 30mm keihins on a drag-port 350 stock stroke?
I have cpi inframes and k&n pods. What needles work? Shees loading
up at 1/4 to 3/4 throttle and then takes awhile to get on the pipe when I pin
it...then she rips???? I have tried all needle positions. A smaller main
helped, but I think I may need a different needle now???
i have a similar problem .. most likly u have to get a diffrent taper needle .. i shouldn't have replied because i know nothing about kehins but i had a similar problem with my mukunis and once i got a diffrent needle it got better ..
My 28 pwk's acted like that when I was first tuning them. The airscrew can make a huge diffrence along with a larger pilot and smaller mains. I run the stock kehin needle at the third clip. To be real honest, my loading up problem didn't go away until I droped in a set of V-force reeds..then my throttle response was amazing. No bog. go from idle to full without hesitation. It takes a while to dial in carbs...trial and error.
