DirtRider Posted July 5, 2004 Report Posted July 5, 2004 i was taking a close look at the pistons to see if i could see a number on them but didnt see any. what i did find is that both pistons move side to side a little bit. is this normL? is it possable i can just get new rings to fit the cylinder instead of boring it out and stuff? Quote
banshee04le Posted July 5, 2004 Report Posted July 5, 2004 Yeah a good amount of side to side slide is normal on the piston pin but there should be zero wobble or play. It should be a tight slide, just how I like it. If the piston is not burnt or scored on the skirt and the bore is measured to be within spec tolerance for the piston then you can run a hone through the cylinder and throw on a new set of rings. Wrong forum section by the way. Quote
locogato11283 Posted July 5, 2004 Report Posted July 5, 2004 youd be a lot better off not doing a halfass rebuild job. just have it bored to the next size up and do it right. Quote
banshee76179 Posted July 5, 2004 Report Posted July 5, 2004 youd be a lot better off not doing a halfass rebuild job. just have it bored to the next size up and do it right. yep, get it done right.. It will pay off in the end! Quote
