Bog
  • 2 weeks later...
Got a question when I hit 6th in or out of the powerband I lose everything. I doesn't die but it doesn't keep reaching in RPMS it just kind of slows and settles. Wondering whats up with 6th
Is this at full throttle or half throttle? If it's wide-open-throttle, it's your main jet. You can kill it holding the throttle open and clutching it to a stop and check the plugs at the bog. The color will tell you if your rich or not. If it's a bog (not sputtering) and it doesn't die, sounds like it could be a lean condition.
