gonzoret Posted June 30, 2004 Report Share Posted June 30, 2004 put some new toomey t-6's on a 2004 banshee. k&n filter with no lid, #280 mains, stock pilots and stock needle on the 4th also still has the tors system. the bike starts and idles without a problem but after you put it in gear its real hard to get it moving it just bogs out real bad, once you start moving and keep the revs high it responce pretty good, but if you let go of the gas and hit it again it bogs and then responceds. what do you guys think is the problem? any advice will help, thanks Quote Link to comment Share on other sites More sharing options...
Brian G Posted July 1, 2004 Report Share Posted July 1, 2004 Why are you on the 4th clip? try the 3rd, also get some 27.5 or 30's pilots. your set up is close to my buddies. It seems like you aint getting enough fuel on the low end. Quote Link to comment Share on other sites More sharing options...
gonzoret Posted July 1, 2004 Author Report Share Posted July 1, 2004 thanks Brian, i'll give that a try. does it matter that the bike is completly stock? Quote Link to comment Share on other sites More sharing options...
Brian G Posted July 1, 2004 Report Share Posted July 1, 2004 The bike isnt stock!!! you got pipes and a k&n without a lid. You seem about right on the main, but stock pilots and 4th clip from the bottom is very lean on the midrange and low end. Where are your air screws at? Quote Link to comment Share on other sites More sharing options...
sandgrencivic2k1 Posted July 1, 2004 Report Share Posted July 1, 2004 I am having the same problem. I have the toomey needle it in now on the 5th spot. I am waiting to get some new stock needles and will put them in on the 4th clip. But what pilots should I be running? I have the t6 pipes, with the uni 2 stage filter, no snorkel, and airbox vents. Other than that I am stock. Any adivce would help. Quote Link to comment Share on other sites More sharing options...
banshdog Posted July 1, 2004 Report Share Posted July 1, 2004 PILOTs, i had the same prob when i first put my PC's on. Quote Link to comment Share on other sites More sharing options...
Banshee169 Posted July 1, 2004 Report Share Posted July 1, 2004 I just installed the TR-6's this week. Running with .020 over wiseco's, pod filter w/outerwear, boyesen reeds, TORS eliminated, running the 280 mains, needle on 4th clip position, and 25 pilots, runs great, snappy throttle response on the bottom and unreal response in mid and top. No problems yet with about 5 hours on the shee. I am at 300 feet and about 90 degrees average temp right now. Hope this is of some value. Quote Link to comment Share on other sites More sharing options...
gonzoret Posted July 13, 2004 Author Report Share Posted July 13, 2004 ok, just changed the stock needle back to the original 3rd position and there was a big improvement in throtle responce, more low and mid power. it might just be me but it seems like it could improve just a little in those parts, or not. want to thank you guys for all the help. P.S. does anybody know anything about Raptors? Quote Link to comment Share on other sites More sharing options...
