CrashFireBanshee Posted June 29, 2004 Report Share Posted June 29, 2004 Hey everyone just got a great deal on a trinity cv manifold with a 34mm pj carb. I am new to playing with carbs. I can't figure out how to get the needle out. Can someone tell me how to take the cap apart. Also what jetting should I try first. My elevation is 1000ft, I have Fatty pipes with power core 2 scilencers. K+N clamp on with no box. and it has been bored .020 over. Thanks for the help Quote Link to comment Share on other sites More sharing options...
brock_fuzzy_69 Posted June 29, 2004 Report Share Posted June 29, 2004 i got the same setup it isnt dialed in yet tho i run about a 165-175 main jet and 48-52 idle to get the needle out you take the slide out and if you slide the cable down and out the side to remove it then with a phillips screwdriver or a 6mm? socket u turn that piece inside the slide a quarter turn then it should come out Quote Link to comment Share on other sites More sharing options...
ngelati Posted July 1, 2004 Report Share Posted July 1, 2004 What were you using with the stokcers? Im running a trinity intake wiht a PJ34 too, Im running a 182 main and a 52 pilot... whit the 26mm mikuni I was running 27.5 pilots and 310 mains Quote Link to comment Share on other sites More sharing options...
brock_fuzzy_69 Posted July 2, 2004 Report Share Posted July 2, 2004 that carb setup was on it when i got the shee so i dunno waht it had in the stock carbs Quote Link to comment Share on other sites More sharing options...
