Keihin PJ 34mm Jetting
Hey everyone just got a great deal on a trinity cv manifold with a 34mm pj carb. I am new to playing with carbs. I can't figure out how to get the needle out. Can someone tell me how to take the cap apart. Also what jetting should I try first. My elevation is 1000ft, I have Fatty pipes with power core 2 scilencers. K+N clamp on with no box. and it has been bored .020 over. Thanks for the help
i got the same setup
it isnt dialed in yet tho
i run about a 165-175 main jet and 48-52 idle
to get the needle out you take the slide out and if you slide the cable down and out the side to remove it
then with a phillips screwdriver or a 6mm? socket u turn that piece inside the slide a quarter turn
then it should come out
