Heres the deal I got Noss Head, Porting Polishing, . 60 over i belive, reed spacers, gold series pipes, powercore 2 silencers heres what im wondering what should my next step be in building a good all around she?? Im thinking a 4mm strokr crank but then i hear ill have to get it ported all over again and my banshee wont rev as fast or high with the 4mm stroker in it is this true?? Also are reed spacers as good as v force reeds?? Thanx for any help or sugestons.. :headbang:
i wouldn't worry about carbs until your stroked. get a timing plate and save your money for the stroker. that's your next big step.
put it on alky if youre gonna drag it, im guessing you are since everyone keeps recommending cpi's. or you could get like 15cc domes from noss and run it on VP 112 octane, thatd smell sweeeeet
im with sredish, get a adj timing plate, port and polsih if u have the money, but im also with dunemon, cause we all know the weak spot of a shee is its handeling, so work on suspension
