ok i got my banshee runnin just the way i wanted it good mixture running fast then two days later it started popping at high revs messed with the jetting mixture is fine rebuilt the topend new coil carbs are synced so n e one got n e other ideas
ok well i had it temporary fixed but shanged the plugs and it sdtarted acting up again and its getting extremly hot extremly fast like less then 5 minutes pipes are so hot and coolant comes pissing out the drain hose or radiator aint found out for sure
  • 3 weeks later...
