tweeded89
Everything posted by tweeded89
  1. ya its not lean thou but ill try that but it only does it when i got my drilled airlid but it still overheats if it aint popping
  2. well the jetting is fine the mixture is a nice color on the plugs but where can the air leaks come from
  3. ok my banshee is over heating and lighltly backfiriong but only when u rev and let off at idle but my mixture is fine everything looked to be ok on the propeller and my mixture shows good so n e ideas n e 1 plz this thing is drivin me insane
  4. ok well i had it temporary fixed but shanged the plugs and it sdtarted acting up again and its getting extremly hot extremly fast like less then 5 minutes pipes are so hot and coolant comes pissing out the drain hose or radiator aint found out for sure
  5. ok i got my banshee runnin just the way i wanted it good mixture running fast then two days later it started popping at high revs messed with the jetting mixture is fine rebuilt the topend new coil carbs are synced so n e one got n e other ideas
  6. tweeded89
    Doh!
    ok this isnt a banshee story and due to my banshee popping i cant even ride it but im sure when i get it fixed ill have some banshee stories due to being accident prone well we got a small sandpit out where i live in durham maine and we built some jumps and i was riding my cr125 which was way to weak for me well i went over a few jumps 1st day i got it and i saw 1 and i got towards the end and was gonna just roll over it so i could check it before i did well come to find out it was dug starit donw bout 2 feet sure enough up and over the handle bars everyone got a goodlaugh when they say the tape to bad i erased over it ergh coulda been a 10k dollar funny video
  7. it does it usually 3/4 to full throttlle elevation well maine whatever our elevation is here its been ported stroker crank .6 over it seems to do it more when its cold and also if u pull the chocke it doesnt seem to do so much and the bottom of the plug is light charcoal brown and it pops when im in the gas and it after 3rd it just pops and continues to pop at wot and will cut out
  8. ok my banshee seems to backfire a whole lot when it gets to high revs im advanced 4 degrees not sure of the jetting and i have two airboxes 1 with hole in it 1 with out they both cause backfiring but the 1 with the holes does and it does it more as u go faster now when running the lid im way to rich with the one with the holes it burns light brown so n e one have n e ideas please help i need this thing tuneeed by next sunday
