BakoBanshee Posted May 26, 2004 Report Share Posted May 26, 2004 I just ordered some new re-packing from Toomey. Is it easy to do? Do you wrap the packing tight or loose around the core insert? Any other tips? Quote Link to comment Share on other sites More sharing options...
Schizo Posted May 26, 2004 Report Share Posted May 26, 2004 Wrap it around just tight enough to slip it back into the silencer but not so tight that it chokes it. Quote Link to comment Share on other sites More sharing options...
hyper_yfz350 Posted May 27, 2004 Report Share Posted May 27, 2004 Do not pack them too tight or you will hinder the performance. They should be somewhat loose. Use some masking tape to wrap them around the core and then slide them into the pipe. Make sure to use some high temp sealant before you completely slide it all the way in. Quote Link to comment Share on other sites More sharing options...
