dnhyoung Posted May 19, 2004 Report Posted May 19, 2004 (edited) I'm ready to spend some money on some carbs, But I am really unsure of what size and type to get. You can see my mods in my signature, and I don't really plan on doing much more to it that will drastically change the engine other than freshening up the top end. Do I want 30mm D slides, 33mm pwk's, airstrykers...what's the best recommendation, and what will my gains be versus cost. I've read some of the back posts, but the more I read, the more I get confused.. Edited May 19, 2004 by dnhyoung Quote
ledofthezep Posted May 19, 2004 Report Posted May 19, 2004 33mm pwk's That would be my choice, should suit your motor well. I don't know much about the airstrykers, so I couldn't help ya there. Quote
dnhyoung Posted May 19, 2004 Author Report Posted May 19, 2004 will there bet that noticable of power gains?? Quote
fixitrod Posted May 19, 2004 Report Posted May 19, 2004 (edited) 35mm pwk's or 34mm mikunis or 34mm pjs. You will not be sorry. I have a 4mil stroker and I couldn't believe the difference from 28mm flats to the 35mm pwks. I gained all the way around. I believe Banchetta had the same experience. Edited May 19, 2004 by fixitrod Quote
dnhyoung Posted May 19, 2004 Author Report Posted May 19, 2004 35mm pwk's or 34mm mikunis or 34mm pjs. You will not be sorry. I have a 4mil stroker and I couldn't believe the difference from 28mm flats to the 35mm pwks. I gained all the way around. I believe Banchetta had the same experience. what type of intake and air filters are you running with this set-up?? Quote
Klotz Posted May 20, 2004 Report Posted May 20, 2004 33 pwk...just installed some on a friends banshee and i couldnt believe it the difference that it made....but ive never rode one with 34 or 35 mm Quote
U8RSAND-Az Posted May 20, 2004 Report Posted May 20, 2004 I ran 35PWK's for years on a ported and loved them. Quote
fixitrod Posted May 20, 2004 Report Posted May 20, 2004 35mm pwk's or 34mm mikunis or 34mm pjs. You will not be sorry. I have a 4mil stroker and I couldn't believe the difference from 28mm flats to the 35mm pwks. I gained all the way around. I believe Banchetta had the same experience. what type of intake and air filters are you running with this set-up?? I run Grand River Racing intakes and an airbox. The easiest way is pod filters though. Quote
John19 Posted May 21, 2004 Report Posted May 21, 2004 Can someone explain to me why it would help you out to get a bigger carb.? I have a ported and polished shee with pipes +3 timing on my plate. I always thought (just my thought) that it only needs to get gas what else could boost power with a bigger carb. also, does it burn alot more gas this way too? Thanks for any input here! Quote
fixitrod Posted May 21, 2004 Report Posted May 21, 2004 Every motor is different. If you engine requires more fuel to run at peak performance for the porting you have you will notice gains. It probably will use more fuel.. but it needs to for the performance. Here's an example. Do you think a 2 barrel carb will work on a big drag car the same as a couple 850 double pumpers. It still gets fuel with the 2 barrel... but it won't run right. Quote
bbluebanshee Posted May 21, 2004 Report Posted May 21, 2004 Can someone explain to me why it would help you out to get a bigger carb.? You can pump plenty of gas througha stock carb for pretty decent mods by way of huge jets. a lot of the problem with smaller carbs is airflow. if you get too much gas, you will just bog the motor down. bigger carbs=more gas+more air=more power. This is the basics in a nutshell. Quote
