luv2ride13 Posted May 13, 2004 Report Posted May 13, 2004 Those degree keys what is the benefit and which on 4 or 7 if i am just jumping it and trailing and ungodly speeds is it worth it? Quote
lian Posted May 13, 2004 Report Posted May 13, 2004 from what i heard the keys are a go good witha pipes and and airbox mod the plus 4 is good for trails and the plus 7 is good for drag but the keys are known to shear off or break and if thats a problem then its best to get a timing plate wich will be alot more relible and they can be adjustable Quote
luv2ride13 Posted May 13, 2004 Author Report Posted May 13, 2004 Thanks, The adjustable timing plate is worth it huh. How do you know how to adjust it and what it is doing. Is it really worth it being that I am just freestyling Quote
evil Posted May 13, 2004 Report Posted May 13, 2004 youll get a little more performance out of it but not like slapping a set of pipes on her. dont go anything over 4 degrees and youll be ok, if you do go over 4 youll over heat it and it will run like crap, and stay away from those degree "keys" Quote
frocashmoney24 Posted May 13, 2004 Report Posted May 13, 2004 get the 4 that way u know u wont be fuckin urself, by to much timing advance, if u ever get the money get the adjustable plate, does wonders u cna change it anytime u want Quote
