i have put fmf pipes on my 2001 banshee also prodesign- cool head with 22 cc domes and v-force reed valves what are some other performance mods i could do thats worth the money
Yes I would give It a good Port Job and use the Vitos Power Pistons. And a Pro Flow Air Filter Kit and a Vitos Degree Key. And I would go done to 20-21cc Domes new set of Tires if you dont have them already. And Filtered Air Vents Boost Bottle and a Clutch Kit to get all This new Power to the Ground :bolt:
Get rid of the TOR's, if you already havent. A good thing to invest in is a Dyna ignition. different handle bars of you choice if they are stock, mine in particular is pro taper, or depends on what your setting it up for.
