My sleeve was cracked on my left cylinder so I took both cylinders to be worked on, one resleeved and one bored out. When I picked them up the wrong cylinder was resleeved and the sleeve was not in straight. So the guy is going to resleeve both of the cylinders again. What should I look for to make sure this idiot did it right this time? Do the new sleeve port holes need to be the ground to the exact same size as the holes in the cylinder?
Thanks,
Greg
