sweetshee4312 Posted May 9, 2004 Report Posted May 9, 2004 ok, well my engine is down to noething, and im onna be puttng back trogether soon....but i need to know about the gaskets and the trans/ seals. I do not know what the tranmission seals consist of, and the gaskets, is there ne thign special i shuld do to get a better seal, and for the cases, how do u use that yamabond shit, do u have to do it juuuust right or u will have a leak, or what... someone give me the down low pleace thanks Quote
sweetshee4312 Posted May 10, 2004 Author Report Posted May 10, 2004 coem on guys, ne thing will do Quote
MotulMonsta Posted May 10, 2004 Report Posted May 10, 2004 O.K. You use yamabond on the case halves make shure the mating surfaces are clean and free of dirt and oil. When you apply the Yamabond, use as little as possible but maintain a good bead..that's the key to getting a good seal. There shoild be no breaks or gaps..As for the seals, you have to buy them..Moose and cometic makes a complete gasket kit for the banshee with everything you need. Unless your running reed spacers, then you'll need to have a total of 6 reed cage gaskets. Do not re-use any of your old seals and gaskets... Your just asking for trouble. Quote
nater006 Posted May 10, 2004 Report Posted May 10, 2004 Lower end seals... should be 7 I believe: (2) crank seals (1) kicker shaft seal (1) water pump seal (1) clutch arm seal (top of case) (1) counter sprocket seal (1) shifter lever seal I think thats it? Thats what I got when re-doing my tranny a couple months ago. But yeah, what MotulMonsta said -- DO NOT reuse any of the existing seals! Spend a few bucks and get a kit by Moose or Cometic. You don't want to be sucking air or anything else into the crank chamber, or leaking gear oil everywhere.. Quote
SICK BOY Posted May 10, 2004 Report Posted May 10, 2004 I got my gasket set,and oil seal set from Vito's for $49.00 for all. Quote
