I'm running 28mm PWK's,pro-design intakes along with the stock airbox.I need the rubber boots from carb to airbox.I cut the stock ones to fit(airbox side).Do they make an aftermarket boot to fit with out modding?
The pro design intakes must sit the carbs back further, because with my stock intakes and 30pwks I dont have to cut anything. You should look into moving the air box back, I think it can be done.
Hmmmmm does moving the airbox back change anything?It would be like a longer tunnel.Would the air flow pick up speed or anything?
The only part that would be spaced more is the reeds to the carbs because of the intake. That is if it does push the carbs back, im assuming so unless you dont have the carbs pushed in all the way. Its already spaced back so in a sense its like having reed spacers behind the reeds. Moving the airbox back to fit stock boots wouldnt change a thing.
Edited by H300F
