wodeman Posted May 3, 2004 Report Posted May 3, 2004 Im trying to access the shift star to see why my trans only has 1st and 2nd gears. I cant seem to get the clutch boss off, i dont have any tools to hold it in place while trying to get the nut off. Any tricks or do I need a special tool. Thanks Quote
wodeman Posted May 3, 2004 Author Report Posted May 3, 2004 But I still need to hold the clutch boss inside the basket to get the nut off. I need an idea of how to hold the boss so I can get the nut off. Quote
DIRTBIKEZ Posted May 3, 2004 Report Posted May 3, 2004 I put it in 6th gear, held the brake and loosened the nut... being that you only have 1st and 2nd that may not work. Quote
frocashmoney24 Posted May 3, 2004 Report Posted May 3, 2004 imact wrench to..but i think i held on to my flywheel when i did mine... Quote
Otis Posted May 3, 2004 Report Posted May 3, 2004 (edited) I just took mine off today. Used an impact, w/ a regular socket and it came right off. No need to worry about holding it in place if your using an impact... Edited May 4, 2004 by Otis Quote
ledofthezep Posted May 5, 2004 Report Posted May 5, 2004 To see if it's bound up you should not have to pull anything off other than the clutch cover. Move your shifter & you'll see where the shift fork grabs the star & you'll be able to see if it popped out and is outside of the star & bound up in 2 gears. If so, take a small flathead & unbind it. I'd recommend shimming up your shifter also after getting the gears unbound. Quote
