streetshee Posted May 1, 2004 Report Posted May 1, 2004 whipped her apart today to hone and new pistons and while i was there i thought fcuk it im gonna port her!! so i opend up the transfers a little,raised the exhaust 1,5 mil,and knife edged the inlet,and widened the inlet ports by 1 mil,matched the piston windows with the inlet,milled the head .25,snorkel off,standard jetting,standard pipe,took her for a steady ride,and was pleasantly surprised on how much shee improved on the midrange,but seams to of lost on top end a bit??? watcha think?? should i of not messed with her? Quote
jeepman380 Posted May 1, 2004 Report Posted May 1, 2004 If you did all that and you are using standard jetting then that might be the problem with your loss of top end. Might want to go up a jet size or two and see if that helps. Quote
streetshee Posted May 1, 2004 Author Report Posted May 1, 2004 she runs rich on standard so i thought id try her as shee is,put new plugs in so tomorrow i do a plug chop and see,old plugs were pretty black,i run 25-1 full syn,yeh i know its a lot but i ride about 1000km a month allways at high rpm. Quote
streetshee Posted May 2, 2004 Author Report Posted May 2, 2004 yeh i know but over here u cant run aftermarkrt on the street,there too loud,and ya get a 3000 euro fine!!! Quote
