HASTY Posted April 28, 2004 Report Posted April 28, 2004 have shaved the head on my shee, now i'm getting clutch slippage, is this indicating worn clutch or need of adjustment??also maybe the fluid , not sure . love to feel the fullness without the slippage though ! Quote
Aussie Quad Racer Posted April 28, 2004 Report Posted April 28, 2004 first of all measure you fibres, they should be between 2.7mm and 3mm. Usually a general clutch service will solve your problem. You need to remove preasure plate, fibres and steel plates and the inner hub. You need to sandblast all the fiction surfaces on the steel plates, inner hub and presure plate. this deglases the surface and roughens it up. Try this first b4 spending the money on a new clutch, unless you clutch is obviously stuffed. Quote
02_banshee Posted May 11, 2004 Report Posted May 11, 2004 what he said^^^^^^^^^^^^^^^^^^^^^^^^^ Quote
