only down side is if you run fat bars youll need a longer steering stem. other then that if i run a mx track i just dont fill it up all the way. on the trails and in the dunes it kicks ass because you can ride for hours and not run out of gas, same as in the desert, you go twice as far. ill usually only put in about 1 1/2 to 2 gallons at the most if im on a mx track or doing alot of jumping.
