i was considering a 38 mm keihin PWK air stryker
anybody ran one on a 2 into 1 intake setup
how did u like it
what mods did you have
did u lose any throttle responce by going to big
all things that i woudl like to get some input on
my mods are
wiseco hot rods crank trued and welded
40? thou overbore
20 thou shaved off head
v force reeds
light flywheel
advanced timing
trinity pipes
trinity 2 into 1 intake
k and n is what i am running now in an uncoverd airbox
might go to a clamp on if i go to the bigger carb
I've got a 35 on it's way to me. I think the 38 is probably going to be a little large for your setup. You'd probably need a pretty heavily modded motor for the 38 to pull harder than a 35. I'm just going on things I've heard from people here and people I know, but they all seem pretty consistent. It sounds like the 35 is just right for your setup.
I also run a 35. I wouldn't go any bigger than that unless you have some good porting and/or a stroker kit. 35 is plenty for a more-or-less stock motor, the overbore won't make much difference. In fact, depending on what your looking for in the performance, the 33mm is said to have better response than the 35 with a stock motor. I have plans on some porting and maybe a 409 sleeve kit, so I opted for the 35mm. Also, when I get the kit together and installed, I will be trying a 38mm to see how I like it.
The bigger the carb gets, it will move your powerband a little farther upward in the rpms. For instance, with the 33mm, the power will come on a little sooner than the 35mm, and I would the same for the 35 and the 38.
Good luck with your decision and let us know how you end up.
Scott
