mellow yellow Posted April 21, 2004 Report Share Posted April 21, 2004 Okay, have a 2002 banshee, CPI inframes, play/race port and polish, v-force reeds, billet high flow manifold reed spacer. +4 advanced timing, cool head with 20 cc domes. Running a proflow 2 into 1 with a K&N, but don't have my air box anymore. I'm currently running 30 pilot and 410 main and it still seems hot? Anyone else have a similiar set up? Any ideas. I run dunes only, at sea level. Quote Link to comment Share on other sites More sharing options...
MULLET~BOY Posted April 22, 2004 Report Share Posted April 22, 2004 410 sounds big i was running 390s with ported reed cages dune porting cpi inframes pod filters 18cc domes douse it feal fat any where on the powerband Quote Link to comment Share on other sites More sharing options...
pimp559 Posted April 22, 2004 Report Share Posted April 22, 2004 If it ain't spitting coolant out of the overflow it ain't hot. Mullet sounds right that seems pretty fat. Quote Link to comment Share on other sites More sharing options...
mellow yellow Posted April 22, 2004 Author Report Share Posted April 22, 2004 I have no complaints. It runs like a raped ape! We got up early one morning, was very cool and brisk, shooting some technical hill climbs, running the piss out of it, and it got really hot. What was weird was it looked more like water than coolant? Just was wondering if someone else had a similiar set up and what they were running. I started jetting at 340 and went up. I had 420 in, but they felt a little boggy. If any thing, it seems a little boggy at the low end. Nothing really significant, but I'm always looking for more throttle response! When I had 380's and 390's in there, it looked darn near perfect. Went up to 410's just to be safe. Thanks for the input. Quote Link to comment Share on other sites More sharing options...
sredish Posted April 22, 2004 Report Share Posted April 22, 2004 How do your plugs look with the 410 in it? If your coolant is no longer, then replace it with some Engine Ice coolant, it will run 40 or 50 degrees cooler than properly mixed auto coolant. Quote Link to comment Share on other sites More sharing options...
Banchetta Posted April 25, 2004 Report Share Posted April 25, 2004 I'd check your water impeller...they are known to fail once in a while.... Quote Link to comment Share on other sites More sharing options...
jp66 Posted May 3, 2004 Report Share Posted May 3, 2004 definately check impeller ,remove it andvisually chek it . mine was broke on theshaft end .the smaller hole were it slides onto the shaft i couldnt tell till i dis-assembled it .ran hot but never o-heated. Quote Link to comment Share on other sites More sharing options...
