Jeff my X gf could start her Banshee pretty easily even though she weighed 100#s. This might be more of a matter of kicking technique rather than actual issues with the machine. My X's Banshee was set up like yours but had the timing advanced a few degrees (3-4). She had a hard time starting it at first as she was more trying to kick straight down instead of back and down. If you have no problems starting it then maybe you need to work with her on kicking.
Goiod idea, she was able to kick it to start with no problems before we put the new pipes on, but has been getting worse and worse over the last year. Your missies was slightly smaller than mine, nice to have small girls hu??? ;) . Thanks for all the info I will be doing some more research on the bike this weekend.
On a Compression check,....Shouldnt the numbers slightly vary one side from the other? My shee reads 110 on one side and 115 on the other.
