Banshee~ Posted April 18, 2004 Report Posted April 18, 2004 Anybody have any problems installing it?The clamps by the arms fit and the ones in middle fit but the ones in back arnt fitting right.What am i doing wrong?plus one of the clamps they sent me was stripped Quote
frocashmoney24 Posted April 18, 2004 Report Posted April 18, 2004 i'd call up wherever u ordered it from and start askin some wtf questions Quote
97blkbanshee Posted April 19, 2004 Report Posted April 19, 2004 DG sucks a$$.I have their a-arm guards and full skid plate.On the a-arm guards 1 of the bolt holes on each side was so tight getting the bolt to thread in. When I tried to back them out the cheesy bolts snapped.The full skid mounted o.k. but the oil drain hole doesn't line up with the drain bolt so when I change the oil I have to remove it or the oil drains all over the top of skid plate and makes a f$@&ing mess.I am going to make the hole bigger next time I have it off.Also make sure you put some anti-seize on the bolts .Those cheesy allen head bolts strip easily.You should pick up some stainless steel bolts .That is what I did . Quote
wansomordis Posted April 19, 2004 Report Posted April 19, 2004 DG sucks a$$.I have their a-arm guards and full skid plate.On the a-arm guards 1 of the bolt holes on each side was so tight getting the bolt to thread in. When I tried to back them out the cheesy bolts snapped.The full skid mounted o.k. but the oil drain hole doesn't line up with the drain bolt so when I change the oil I have to remove it or the oil drains all over the top of skid plate and makes a f$@&ing mess.I am going to make the hole bigger next time I have it off.Also make sure you put some anti-seize on the bolts .Those cheesy allen head bolts strip easily.You should pick up some stainless steel bolts .That is what I did . Hmmm I was starting to think I was the only one that was having problems with those cheap allen head bolts.. Pretty bad the bolts are hard to tighten even when new Quote
ledofthezep Posted April 19, 2004 Report Posted April 19, 2004 I helped a buddy put one on his shee a while back. It didn't exactly go on like butter, but wasn't too bad. My best suggestion is put all the mounts on & leave them loose until you get all mounted, then tighten them all down. Quote
Banshee~ Posted April 20, 2004 Author Report Posted April 20, 2004 Any other brands that are good?I want the little flange that sticks up on the sides. Quote
DUNEDEMON Posted April 20, 2004 Report Posted April 20, 2004 http://www.prm-atv.com http://www.umracing.com Quote
