this is what im getting done:
1. LRD Pipes
2. MX Porting
3. Cool Head
4. Lighten fly wheel
5. Boyesen Reeds
6. Wiseco heads
I will be riding mostly in the 3000' elevation. What size keihen should i get
Edited by mrman99
For mx, I like the 2 into 1 carbs better. If your going to get a 2 in 1 get the 35mm and if you want to stick with duals look for 28-30mm's.
yeppers, the 2:1 carb is a great mx setup, no doubt!! also right on with the dual carb sizes.
FoxBansheeRacing, you need to get your shee in on the Images section for the banner stuff, it looks sharp.
Excuse me for my ignorance, I looked at keihin's webpage and didn't see any productline thats for 2 into 1. Is it the same as the dual carbs, but only using a single carb that is bigger to compensate for 2 smaller ones? Can someone give me a link, or some part #'s. I would like to do some more research.
it is simply a Keihen 35mm PWK carb. Go to CarbParts.com and click on Keihen, then on the Off Road link, or smaller links to the right regarding the specific parts and tuning. Anything that specifies PWK is what your after.
