99screaminshee Posted April 13, 2004 Report Posted April 13, 2004 hey guys i just finished puttin the shee together from the winter rebuild now i need to know what is a good tranny fluid and what r the advantages/disadvantages of runnin 2 quarts i already had my ball and rod weld so i had to fix that thanx Quote
BansheeBrian Posted April 13, 2004 Report Posted April 13, 2004 (edited) ATF type F seems to be a favorite.I have not heard anything bad about it. Too much tranny oil may cause some slippage. may want to stick with the 1.8qt or for just a change 1.6qt. Edited April 13, 2004 by BansheeBrian Quote
sredish Posted April 13, 2004 Report Posted April 13, 2004 I use Silkolene Comp Gear. *A race proven, synthetic based gear oil for off road competition bikes. It is also ideal for road and race machines with separate gear lubrication. *Effective over a wide temperature range, it gives smooth gear changes, postive clutch action and reduces wear, especially where aluminium clutch plates are used. *Can be used wherever SAE 10W/40, 80W or 90W oils are recommended A lot of people use the ATF and some use 10W30, but I like something specifically designed for the wet clutch application. It may be nothing more than a sticker on the bottle and higher price tag, but it makes me feel better. Quote
dansheeman Posted April 13, 2004 Report Posted April 13, 2004 belray gear saver is all i ever use my brother uses yamalube my gear save works great Quote
TREELIZARD Posted April 13, 2004 Report Posted April 13, 2004 i use 2qts of atf type F. i have read somewhere before that the little bit of extra oil helps prevent welding the clutch ball to the rod. Quote
Banshee~ Posted April 13, 2004 Report Posted April 13, 2004 bel ray gear saver works good for me Quote
MULLET~BOY Posted April 14, 2004 Report Posted April 14, 2004 some honda crap in a red jug that cost like 10 bucks works good and is thick Quote
DUNEDEMON Posted April 14, 2004 Report Posted April 14, 2004 Hinson (the clutch company) just introduced a new line of clutches and fluid specificaly designed for wet clutch applications, I'm going to try it out. http://www.hinsonracing.com Quote
sweetshee4312 Posted April 14, 2004 Report Posted April 14, 2004 im with zep, i go by the manual , im alo woundering, around here int eh winter it gets cold, so if someones running 80w oil, thats gotta get pretty sludgy like, how can that be better for ur engine??? Quote
99screaminshee Posted April 14, 2004 Author Report Posted April 14, 2004 thanx for the ideas guys i went out and got sum gear saver this morning and put 2 quarts in and got her up and runnin after the rebuild i will try to post sum pics of it tomarrow or the next day its nice out thanx again Quote
