I turn my front stock wheels around in the front to try and get more width for stability(adds about 2-3" on each side) and the valve stem hits the calipers on the front when the wheels roll. HOw can i put the valve stem on the other side of the wheel???
drill a hole in the other side and ive seen guys put the valve stem in backwards when doing this to seal the hole up and keep it from hitting the calipers.
Just to clear that up, you take the factory valve stem, and turn it inside out, so the valve stem is now INSIDE the tire. Then, 180 degrees from the stock hole, you drill a hole on the OTHER side of the rim. And install a valve stem in the normal fashion. This will be the new outside of the wheel.
I used flush mount valve stems, that way I can flip them either way.
I wouldn't recommend flipping your tires though, If you have too much offset you will have wicked bump steer, I hated it and widened it the right way, a arms
Edited by rzcolobanshee
