canadabanshee Posted April 9, 2004 Report Posted April 9, 2004 I think i got a carb problem. I just changed the jets. Its running great everything is good. But I put both carb caps on and tighten them down to 2.5ft each. But the top of the carb where u adjust the Idle speed they move a little bit. I am not to sure if they did before. Everything is tight. when you rev it up you can see them move. But everything is doing good she runs great Quote
sredish Posted April 10, 2004 Report Posted April 10, 2004 Sure it's not just vibration from the motor when you rev? Quote
stoney Posted April 19, 2004 Report Posted April 19, 2004 i have a 2002 banshee it's piped and jetted with k&n filter .well the guys that did the jetting cut the idle control wires now itwont idle. so i spliced the wires back together and it seems stuck wide open. any one have any suggestions? Quote
