I'm new here so i don't know if this question has been asked or not. When I start up my 95 'shee, it revs up high as hell, but when i shift it into gear and ride around it settles back down. changed the plugs so many times drainded the gas and carbs, still does it. It is stock engine-wise and I run Klotz mix at 32:1. I have been told if mixed gas(especially Klotz) seperates and you burn either straight gas or oil if it has set a while and seperated. would this make it rev up high like that? but even when i shake the hell out of it it still revs high?? need help quick!
Hey D'lo, just a word of advice seeing you're a newbie...do not post the same exact question in more than one forum. The only thing you'll get back from it is disrespect and pissing folks off. We try to keep things organized around here and for a good reason; every forum is read just as much as the others so there is no need to put a topic in two or more forums. You have replies on your other post, check em out ;)
