Chain Slack?
loganskinner
ur manual has easy step by step guidelines w/pics. about 1/2 way up ur swing arm, the chain should move something like 1/2 to 3/4 of an inch (the exact #'s are in the manual). to tighten first you gotta loosen the 4 bolts, loosen the lock nuts, and turn in the adjustment screws. be sure to turn them the same amount so your axle stays lined up correctly. and dont forget to tighten the lock nuts again.
