I noticed my banshee would turn way to much to the left almost to the point where the tires hit the a arms, after I took a look at what was going on I noticed there is a chip on a peice of frame I guess missing which is where the steering stem hits so it can no longer turn in "x" direction anymore. Apparently the last owner must of taken a hard turn or something and knocked a peice off of that off, is this common? What do you guys do to fix the problem?
another one bites the dust !!!! if you cant bend the stop to meet the stem then youll have to weld and grind it.
I noticed it on mine one day and just bend it back (before the powdercoating)..Then looked at a buddies and his had wore a grove in it. But after bending his back works just fine..Factory P.O.S. :D How about a close up of that frame
