got1banshee Posted March 29, 2004 Report Posted March 29, 2004 As most of you know I have resently put yfz shocks on me quad, and let me tell ya these things are awsome. I have only riden it in a field behind my house and it rode pretty damn good, I was impressed on how smooth it was on the bumps. Well anyway to my point of posting this. I have been told how to adjust the rebound on the shocks, well while doing this I notices a screw and when I turn it.....it clicks. What does it do and how do and how does it work?? Quote
banshdog Posted March 29, 2004 Report Posted March 29, 2004 I believe that is the adjustment screw which controls te rate at which the gas can travel in and out of the resivior. Quote
got1banshee Posted March 29, 2004 Author Report Posted March 29, 2004 How exactly does it work? Does it get smoother the farther in you go or the farther out you go?? Or is that even what it does? Quote
ikikazz Posted March 29, 2004 Report Posted March 29, 2004 compression is the top rebound it the bottom the farther it is closed less nitrogen goes through which makes it harded to compress the less the easier it is to compress the shock. the spring is what sets your ride height. Quote
got1banshee Posted March 29, 2004 Author Report Posted March 29, 2004 compression is the top rebound it the bottom the farther it is closed less nitrogen goes through which makes it harded to compress the less the easier it is to compress the shock. the spring is what sets your ride height. Right on, thanks guys Quote
erbilabuc Posted March 30, 2004 Report Posted March 30, 2004 compression setting is how fast or slow the spring will compress rebound is how fast or slow the shock will go back to normal position after compressing Quote
demsy Posted April 4, 2004 Report Posted April 4, 2004 got1:::does the qsm arms come that close to the shock??? Quote
got1banshee Posted April 4, 2004 Author Report Posted April 4, 2004 got1:::does the qsm arms come that close to the shock??? They fit alot better than the uglys, the shock rubbed on the ugly arms Quote
demsy Posted April 4, 2004 Report Posted April 4, 2004 good, cause i got so pissed of that my ugly arms hit the shock that i sent them back.. i called gary and ordered some from him,,,, i guess we learned the hardway but the rest of bhq knows now... Quote
got1banshee Posted April 5, 2004 Author Report Posted April 5, 2004 Yeah, this really hurt his buisness I bet. Sucks to be him!!!! I see hime changing the name of his a arms again haha Quote
STLbanshee Posted April 7, 2004 Report Posted April 7, 2004 ok, question for you, what kinda a-arms you got, and did you have to modify the a-arms for them to fit? Quote
got1banshee Posted April 8, 2004 Author Report Posted April 8, 2004 ok, question for you, what kinda a-arms you got, and did you have to modify the a-arms for them to fit? I have quicksand arms and I didn;t have to do anything to the arms for then to fit. Quote
