hi,
.040 over vito's Super stocks
4 degree key
hemi head w/ 22 cc domes
TDR carbon reeds w/ cage mod
Stock carbs (jetted)
K&N filter w/ outerwear
NO AIR BOX LID
Toomey T-5's (jet hot coated)
Hush kit
I called Vito's and got a jet kit for use w/ no air box lid
came w/ 300 mains
melted the right side piston on the exhaust side.
the last time the bitch blew it was the same side, same look
What is the best way to check for an air leak??
300's too small???? banghead
Need to know what alltitude your at.
Most of the time both cylinders will look bad if you seized it.
I run a 370 in Glamis(sea level) with about the same mods but mine is ported.
my other one runs 360main at Glamis.
Up her in AZ mountains at about 5000 ft I run a 240 main
Since your tearing it down I would do an air leak test before you get to far into it.
I had some pics of my home made test kit but cant post them here so if you need some pics of it give me your email adress
Eric :D
i dont think it would even run if it was in backwards. i got fmf fatties v-force reeds k&n with no lid and im running 300 mains, but i dont have the superstock pistons. i put a superstock piston, pro circuit pipe+sil, k&n with no lid on a blaster with 300 main and had no problems. it sounds like an air leak on that side, i would assume that the exaust after the burn is so hot from being lean that it burned up that side of the piston. where the leak would be from, could be anywhere.
